2018-07-19 - Kernels, Themes, DEs, VirtualBox, Haskell (Testing Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Hi community,
Welcome to another testing update. So what do we have with this one?
we added the latest kernels
updated some of our themes
added some more patches and tweaks to GTK3-Classic
added some more KDE, Cinnamon and Deepin packages
Virtualbox got updated to v5.2.16
the usual haskell rebuilds
Please use sudo pacman -Syyuu when you had updated your system yesterday or the day before.
If you are curious about the latest state of development for the upcoming Manjaro-Illyria 18.0 release, you now have the opportunity to download a beta-build  of Manjaro-Xfce 18.0 including the latest xfce-gtk3 packages aswell as our most recent styling efforts:
Our KDE fans may try our beta-build  with the latest KDE v5.13 instead.
Latest information about the intel-cpu-bug risk and our efforts can be found here.
Current supported Kernels
linux316 3.16.57
linux318 3.18.115 [EOL]
linux41 4.1.52 [EOL]
linux44 4.4.141
linux49 4.9.113
linux414 4.14.56
linux415 4.15.18 [EOL]
linux416 4.16.18 [EOL]
linux417 4.17.7
linux418 4.18-rc5
linux414-rt 4.14.52_rt34
linux416-rt 4.16.18_rt9
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Re: 2018-07-19 - Kernels, Themes, DEs, VirtualBox, Haskell (Testing Update)
Beitrag von linuxkumpel »
Xfce keine Probleme.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Ich hatte auch keine Probleme.
sunburn123
Has thanked: 1 time
Beitrag von sunburn123 »
Eigentlich auch alles gut. Nur seid Update auf 4.17 blinkt die DVD LED im Sekundentakt.
