Hello community,
I am happy to announce another Testing Update!
After three weeks of vacation in Vietnam I'm back to rumble.
This update holds the following changes:
Calamares got updated and rebuild against kpmcore 4.0
Grub package got redesigned to support also 32bit UEFI installs. Hopefully the languages bug is also solved by this
KDE-Dev ISO got updated and therefore all KDE-Git packages aswell
Most of our Kernels got updated. Some might had noticed that dmesg is now restricted to root. To rave you can go here.
Manjaro-Tools got adjusted to work better with Ruffus. Issues can be discussed here.
XFCE-GTK3 got renewed packages
Also Gnome got updated to 3.32.2.
For all using Haskell, you find now the latest updates in our repos.
Give us the usual feedback and let us know what you think about this update.
Current supported Kernels
linux316 3.16.65
linux318 3.18.139 [EOL]
linux44 4.4.179 (no legacy nvidia-340 module!)
linux49 4.9.173
linux414 4.14.116
linux419 4.19.40
linux420 4.20.17 [EOL]
linux50 5.0.13
linux51 5.1.0 (few extramodules build, but not all yet!)
linux419-rt 4.19.37_rt19
linux50-rt 5.0.10_rt7
A detailed list of the package changes can be found here.
2019-05-07 - Kernels, Gnome, Calamares, Grub, Manjaro-Tools, Haskell, KDE-Dev (Testing Update)
linuxkumpel
- CPU: Intel Core i3-4030U 4x 1.8GHz 64 bit
- GPU: Intel Haswell-ULT (Intel HD Graphics 4400)
- Kernel: 5.15 / 6.0
- GPU Treiber: Intel i915
- Has thanked: 15 times
- Been thanked: 36 times
Re: 2019-05-07 - Kernels, Gnome, Calamares, Grub, Manjaro-Tools, Haskell, KDE-Dev (Testing Update)
Auf beiden Maschinen jetzt Kernel 5.1 unter der Motorhaube. Alles ohne Probleme gelaufen.
- Administrator
- CPU: Intel® Core™ i7-2630QM
- GPU: Intel UHD Graphics
- Kernel: 5.6
- Has thanked: 208 times
- Been thanked: 152 times
Themen Author - Moderator
Wieder ist alles ohne Probleme.
