2016-07-27 - Kernels, Plasma, Apps, Framework, Calamares (Stable Update)
Hi community,
seems it took us a little longer than we had thought on getting a new stable update out there. We finally made it! Also some of you might have noticed that our main homepage is back up, that we have now a new bugtracker , our wiki  is shining and we have again access to our classic forum , if people want to use that more than our new discourse one. So what changed with this update?
Most of our kernels got updated to their latest point releases
Additionally to 4.5.7 we have now 3.19.8.23 and 4.2.8.13 tagged as EndOfLife (EOL). We will remove them all with our next update!
QT got updated to 5.7 series (please read our troubleshoots to avoid issues with your theming)
Our KDE edition gained Plasma 5.7.2, Apps 16.04.3 and Framework 5.24
Firefox got updated to 47.0.1 and Thunderbird to 45.2.0
Mesa gained new features and is now at 12.x series
We updated most of Python and Haskell packages
Lumina Desktop is almost ready to see its first stable release (1.0b2)
With Calamares 2.3 we support now end2end luks encryption incl. swap
Much needed security fixes added
Archlinux upstream fixes are now from: Tue Jul 26 07:41 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. The complete package list can be found here .
Kind regards,
Troubleshoots
GTK3
You can install it with:
QT apps style with GTK
With QT 5.7 you need to install qt5-styleplugins and qt5ct and configure your system to have an unified look again (If you use applications with root-rights, do the same for your root user) .
ufw
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.102
Linux312 3.12.62
Linux314 3.14.73
Linux316 3.16.36
Linux318 3.18.37
Linux319 3.19.8.23 [EOL]
Linux41 4.1.28
Linux42 4.2.8.13 [EOL]
Linux44 4.4.15
Linux45 4.5.7 [EOL]
Linux46 4.6.4
Linux47 4.7.0
Package changes
community i686: 941 new and 897 removed package(s)
community x86_64: 945 new and 898 removed package(s)
core i686: 72 new and 69 removed package(s)
core x86_64: 72 new and 69 removed package(s)
extra i686: 1056 new and 1011 removed package(s)
extra x86_64: 1056 new and 1011 removed package(s)
multilib x86_64: 37 new and 38 removed package(s)
Zuletzt geändert von Blueriver am Mittwoch 27. Juli 2016, 21:22, insgesamt 1-mal geändert.
Re: 2016-07-27 - Kernels, Plasma, Apps, Framework, Calamares (Stable Update)
Das Update lief sauber durch und alles funktioniert einwandfrei.
System:    Host: Dirk Kernel: 4.7.0-0-MANJARO x86_64 (64 bit gcc: 6.1.1)
           Desktop: Xfce 4.12.3 (Gtk 2.24.30) info: xfce4-panel dm: lightdm
           Distro: Manjaro Linux
Protector
Beitrag von Protector »
Jau, Update lief sauber durch und es gibt keine Probleme :) Allerdings hatte ich befürchtet, dass es gar keine Updates mehr gibt, weil ist ja doch schon über 1 Monat her :)
Shakatus
Beitrag von Shakatus »
Auch ich...
...bin froh über dieses Update. Läuft prima, sogar mit Kernel 4.7.0! Im Zuge dieses Updates haben sich auch einige kleine Darstellungsprobleme gelöst, die ich (unter KDE) hatte.
Mein Manjaro-Ultrabook fühlt sich wieder taufrisch an - und den (perversen  1)) Gedanken, den ich in der langen, updatelosen Zeit hatte (...noch schnell das Original-Windows auf dem Acer-S7-393 zu installieren, um kostenlos auf Windows 10 updaten zu können...) habe ich wieder verworfen!  :D
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Has thanked: 15 times
Been thanked: 36 times
Beitrag von linuxkumpel »
Update ging problemlos. Probleme gab es erst danach. Darstellung der Fenster und Anwendungen war katastrophal. Habe mich z.B. zunächst von Compiz verabschiedet und Thema geändert. Jetzt kann ich sogar schon wieder die SchließKnöpfe sehen.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
LuMI
Beitrag von LuMI »
[quote="linuxkumpel"]
QT5.7 ist genauso ein Rotz wie GTK3.20  ^-^ ^-^ ^-^
Das kann Ich so Unterschreiben..Compiz kommt bei mir auch wieder runter. Nur Darstellungsprobleme und Fenster sehen grauenhaft aus...... :'(
linuxkumpel
Kernel: 5.15 / 6.0
@manjarofan
Das soll die Lösung sein, sofern Compiz genutzt wird (Beitrag von thomb)
"... downgrading metacity to 3.18.4 ..."
Ich kann auch ohne Compiz leben, wollte es mal ausprobieren.  8)
OK, heißt?
Im Terminal ein geben? Paketmanager??? Weiß jetzt nicht ganz genau was Du mir damit sagen willst.
Im Terminal eingeben
sudo pacman -S downgrade
dann
downgrade metacity
Version auswählen
Danke, wird getestet.  ???
