CUPS-PDF Druckaufträge schaffen es nur bis in die Warteschlage
Die_Kralle
CPU: Intel Core i7-4700HQ
GPU: Mesa Intel HD Graphics 4600 (1,5 GiB) + GeForce GTX870M
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
GPU Treiber: video-hybrid-intel-nvidia-390xx-bumblbee
Has thanked: 34 times
Beitrag von Die_Kralle »
inxi -Fz
System:
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
Machine:
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    BIOS: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 52.3 Wh (98.7%) condition: 53.0/77.0 Wh (68.9%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 904 min/max: 800/3400 cores: 1: 800 2: 800 3: 1103
    4: 1332 5: 800 6: 800 7: 800 8: 800
Graphics:
  Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB
  Display: x11 server: X.org v: 1.21.1.10 driver: X: loaded: intel dri: i965
    gpu: i915 resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: crocus,swrast platforms: x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
    renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
Audio:
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    driver: snd_hda_intel
  Device-2: Intel 8 Series/C220 Series High Definition Audio
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active
Network:
  Device-1: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
    driver: wl
  IF: wlp3s0 state: up mac: <filter>
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: IMC Networks BCM20702A0 driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up address: <filter> bt-v: 4.0
Drives:
  Local Storage: total: 1.6 TiB used: 688.41 GiB (42.1%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.67 GiB used: 55.24 GiB (23.6%) fs: ext4 dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2200
Info:
  Processes: 253 Uptime: 2h 21m Memory: total: 32 GiB available: 31.23 GiB
  used: 3.57 GiB (11.4%) Shell: Bash inxi: 3.3.31
Ich habe jetzt mal wieder mittel "cups-pdf" eine PDF erstellen wollen, aber Druckaufträge landen nur in der Warteschlange, werden aber nicht ausgeführt.
Da heißt es dann eine Zeitlang "Ausführung läuft" und dann "Es gibt ein Problem beim Senden des Dokuments".
Es gibt diese Diagnose-Infos:
cups-pdf-diagnose.txt.zip
Diagnose Daten
(4.74 KiB) 76-mal heruntergeladen
Deinstallieren funktioniert wegen Abhängigkeiten nicht und ein "Neu installieren" brachte keine Änderung.
Wie bekomme ich das Tool wieder zum Laufen?
Gruß Heiko
